| Message |
So I rebuilt my engine a few months ago, had a heck of a time getting it running and after it was finally drivable it lost the number 5 cylinder. Everything checked out good until I finally bought a leakdown tester, which indicated that air was escaping from the intake valves. So I tore it down, and found that the valves were worn. What's odd about that is that I had a valve job done and three valves had been replaced because the old ones were extremely worn.Here's one of the valves that came out after 175000 miles:
 Now the only valves that are worn out are the three that were replaced, and I've only put about 500 miles on it. Both the valve and the valve seat are worn into a curve and the valve needs to sink into the head to fit, but the lifter is holding it open. It will hold 85 percent of the air in a leakdown test cold with the cam out. Heres a couple pictures of the new valves:
later, eric
